Astar LTV-3001 Television Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound when tv switched to dvi Astar model LTV 3001
Anonymous
Level 3:
  • Master 405 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
Answers
405
Questions
Helped
233881
Points
1272
There is no audio in DVI connector, you need to run separet cable for audio signal.
1helpful
Power supply burned
These power supplies are not longer being manufactured and very hard to find. The defective power supply can be repair.
If you need further assistance, write to [email protected]
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
I didn't get a manual when I purchased my TV
I have worked as an Electronics Tech in Astar before closing and I have collect all the model information, hope this is help.
At this point I only have the Astar model manual; 19bg, 2001, 20PW, 20SD, 26ASB, 27ASB, 32ASB, 26OB, 3001, 3201, 32BG, 32HBG, 37HBG, 42HBG.
I will update on the LTV-2701 by contact me at 323-767-6030
2answers
Astar LTV-3001 just shut off and I can smell something. Any ideas?
The power supply most likely failed on your LCD.
How old is your LCD?
If it is under a year old, can be fix under manufacturers warranty. If not, you can write to [email protected]
2answers
Astar LTV-3001
I've sent you the info to your hotmail.
1helpful
Astar ltv 2601
Try call my friend Ivan at 323-767-6030 he know where to get the original Astar parts.
2answers
ASTAR 20'' LCD TV
TO ALL WHOM IT MAY CONCERN REPLACE THE WHOLE SUPPLY WITH NEW ONES AS IN 2OR3 SEPARATE ONES FROM HALTED ELECTRONIC SURPLUS OR HSC IN SUNNYVALE CALIF 408 AREA CODE LOTS OF ROOM
NO PICTURE OR SOUND.
Have you guy check the power supply for your TV?
Call me 323-767-6030 and I will go through with you.
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Top Astar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
