If you are using a Motorola cablebox, you may need to change the Audio in the cablebox to Heavy Compression. You can find this in the cablebox Menu, Setting, Audio. Set the audio to Advanced then change the compression.
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Different channels have different aspect ratios on digital cable. Go in your book that came with set and find changing aspect ratio...or call 4.3 16.9....or zoom.....full....streach...etc. Also look on your remote control. There may be a button to change that also. Simple problem. The hardest thing with these new sets is learning how to operate them properly. Read your book. Put it in the bathroom. You'll have alot of time to learn about your set if you do that..I'm serious. This new stuff has so many things it can do, it's crazy!! And you thought setting the time on the vcr was hard!!!! Good luck and let me know if you need more help.
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
