we did that,unless lint is stuck inside dryer. I also saw a comment about fuses in this model,if so where are they?we did that,unless lint is stuck inside dryer. I also saw a comment about fuses in this model,if so where are they?
You can't post conmments that contain an email address.
dryers don't have circuit breakers in them you do have them in your house fuse box,you must mean like the thermal fuse or high limit fuse,if the dryer isn't running these are the things you want to check,also if the dryer and vent line haven't been cleaned out and you might have noticed that it was taking loner for your clothes to dry,this will blow one of the t-stats as a safety,all a dryer does is move air,if you have a block in the dryer or vent line one of the fuses pop from the dryer heating up to much from the block so clean out the dryer and vent line before you run the dryer again if you fix it because the t-stat that was blown will blow again.
underneath the lint trap is the sensor, it is dirty. You will need to
clean it, just be gently as if not you may break it, when you look down
the lint trap it has two screws.
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Child Lock: Press and hold DRY LEVEL for 3 seconds. A single BEEP Tone is heard, and CL is displayed. To unlock, press and hold DRY LEVEL for 3 seconds. The indicator light turns off.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
