Yamaha NP 30 76 Key Lightweight Digital Grand Piano with Touch Response Logo
Posted on Dec 30, 2009
I need the user's manual for yamaha keyboard NP 30
  • Anonymous Mar 28, 2014
    After about five minutes, the keyboard power shuts off. I've only experienced this when there was no one playing it and I don't know if it does it while you are playing. But logic tells me it would.
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
Helped
8188
Points
97
Check manufacturers site or go to some .torrent sites i'm sure you will be able to find somewhere there
2answers
USER MANUAL FOR YAMAHA CVP75 PIANO
Google can be a miracle for finding manuals. Type in specifically what you need!
Sustain Pedal works intermittently.
To start with always best to use the correct power supply these should be readily available from any good Yamaha store. Is the sustain pedal a Yamaha pedal? The plug end of the pedal connect a multimeter across the two connectors and set meter to show continuity. If there is no continuity press pedal, hopefully this will now respond. If not then the break is in the pedal. If meter idea works then it could be the socket on the keyboard, these can work loose on the pcb they are mounted to if they are used a lot.
You could open up the keyboard and look inside checking the solder joints on the socket or simply take to a Yamaha service centre.
You could also try a master reset of the keyboard, hold down the highest note whilst turning on, this will reset to factory default.
Let me know how you get on.
1helpful
2answers
Yamaha P-70 digital piano. A few keys are making a loud knocking noise. The note still sounds, but the knocking noise on the few keys can be heard at the other end of the house
There's an extremely comprehensive pair of videos about repairing this problem on YouTube thanks to David Allyn. I have embedded them below, or you can search "P70 Noisy Keyboard Repair".
Yamaha np30
PLEASE DESCRIBE YOUR QUESTION FULLY........................
I require a user manual for a Yamaha PSR 6000 Organ to down load
Yamaha has the user's guides available as PDFs for most of their instruments on their site: http://download.yamaha.com/top/?site=usa.yamaha.com&language=en . Enter PSR-6000 or select Pianos & Keyboards > Portable Keyboards > PSR-6000 and then press Select.
The link to the manual will display below the search area.
I hope this helps.
A message came up briefly when I turned the Yamaha DGX-203 keyboard on that read "Allmem - Clr" and all my users songs were deleted. Is there anyway to get them back and prevent this problem in...
Contact Yamaha directly. Parts Consumers Support: By Phone: Monday through Friday
8:30 am to 5:00 pm Pacific Time
Tel:(888) 892-6242
After hours or weekends
Tel:(855) 322-3309
Here's a link to a third-party owner's manual
https://www.manualslib.com/manual/539184/Yamaha-Portable-Grand-Dgx-205.html
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
