Our new Samsung fridge w/french doors, bottom fridge, has horrible tasting water. Foul, plastic taste that won't go away despite running gallons of water out of it. Any ideas?
Re: our new Samsung fridge has horrible tasting water
Add water filter system to the unit .. if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
I agree with Gramps... the system needs to be flushed, but one question... why did you change the filter in the 1st place... was it cause you had a smell or taste in the water AND ice, or the filter light came on?? I would remove water line going to ref from house plumbing... run water in bucket for 2 min, then take a small taste to see if good..If water taste good, then hook water line back up to ref, and run water at the door for about 1/2 gal, then taste and smell water to see if it passes... If still have problem, you are going to have to replace filter head and/or water reservoir.... But before i did that i would contact Samsung to get their take, depending on age they might send parts at no charge to you the consumer....... Ken Hawk
preferred Samsung servicer
I have the same problem. I bought an lg French door fridge 6 weeks ago. The ice cubes still taste like plastic. I continually empty the ice bin hoping that the next batch of ice will taste normal. Nope.
There is nothing in my freezer with freezer burn. My previous fridge had an ice maker and there was no problem whatsoever. I had copper tubing. When they delivered this fridge which is 3" wider they said I needed to buy a different supply line because the copper didn't allow it to come out far enough from the wall.
Try and get some ice machine cleaner to run through it,lot of trouble but I would say you have something in there did you have a filter on your supply line?
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
You said, Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You
replaced the copper tubing which delivers the water to the fridge and
that didn't help. You replaced the copper tubing again with plastic
tubing...no better. Any suggestions? Your tap water doesn't taste this
bad.You bought a Kenmore french door fridge with water dispenser in the
door in July 2008. The fridge has a filter. A few weeks after the
fridge came the water and ice started tasting really bad, unlike any
bad water taste I have ever tasted. And your tap water is fine. The bad
taste appears to be random. Sometimes you get a cup full of nasty water
and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions! Did you do this before connecting the water line to your fridge? "Place the free end of the tubing in a container or sink, and turn ON the main water supply. Flush the tubing until water is clear. Turn OFF the shutoff valve on the water pipe. Coil the copper tubing."
Whirlpool remedy Off-taste, odor or gray color in the ice 1.Are the plumbing connections new, causing discolored or off-flavored ice? Discard the first few batches of ice. 2.Have the ice cubes been stored too long? Throw old ice away and make a new supply. 3.Does the freezer and ice storage bin need to be cleaned? See “Cleaning” or “Ice Maker and Storage Bin.” 4.Has food in the freezer or refrigerator been wrapped properly? Use airtight, moisture-proof packaging to help prevent odor transfer to stored food. 5.Does the water contain minerals (such as sulfur)? A filter may need to be installed to remove the minerals. 6. Is there a water filter installed on the refrigerator? Gray or dark discoloration in ice indicates that the water filtration system needs additional flushing. Run additional water through the water dispenser to flush the water filtration system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to 7 minutes initially). Discard discolored ice. Let me know what works, Thank You , HUUUM!!
