When we start a cycle, the water only dribbles into the machine. The water runs fine thru both hot and cold pipes but not into the basin.
Help please
wont agitate, wont spin dry fully
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Start a new wash cycle and then turn the temp selector to cold.....is it filling with cold water? Now try the hot, is it filling with hot water?
try replaceing the lid switch if washer will not spin
If the clothes are not washing then It is a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it.
In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed.
f the agitator is not turning, then the problem is wid motor coupling If it won't
spin (but sounds like it wants to with the lid down), the clutch needs
replacing. More than likely, the transmission will need replacing too
(oil has leaked out of the transmission onto the clutch). If that IS
the case, and you ONLY replace the clutch.
already tried wont wash and wont spin dry
the water fills ok,it just wont wash the clothes and will empty ok but wont spin dry either,And dose the same thing for the different cycles.the machine is a hoover 750LC,
7.5kg heavy duty top loader.
How do i remove the iner bowl to see if a sox or something else is causing the problem.?
I turned the belt manually and it moves freely, so I checked the belt and the belt is ok too.Looks like the lid switch is working too.
