When I turn on my laptop, everything is normal until it is time for the logon screen to appear. A message is displayed on the black screen. It says " Interactive logon process initialization has failed. Please consult the event log for more details." What can I do?
Try it in SAFE MODE... this will fix errors... then restart the computer.
A runtime error is an error that occurs during the execution of a program. In contrast, compile-time errors occur while a program is being compiled. Runtime errors indicate bugs in the program or problems that the designers had anticipated but could do nothing about.
The runtime or run-time error message can be caused by:
1. Confliction with TSR or other running program
2. Software issue
3. Computer Virus
4. Memory issue
Short for Terminate-and-stay-resident, a TSR is a software program that remains in memory until it is needed, and then performs some function. An good example of a TSR is a Virus Scanner, which must remain loaded in memory to help protect your computer from computer viruses.
If you are encountering a runtime error message while in Windows or above ensure that the issue is not being caused by a third-party program or TSR by end tasking all open programs.
If, after end tasking all TSRs, you continue to experience the same issue and are running Windows 95 or Windows 98, verify that no utility or program is being loaded in the autoexec.bat / config.sys that is causing your issue by temporally renaming the files. To do this, follow the below instructions.
1. Boot to a MS-DOS prompt.
2. Once at the MS-DOS prompt, type:
cd <press enter>
ren autoexec.bat autoexec.ch <press enter>
ren config.sys config.ch <press enter>
Once completed, reboot the computer.
2. Software issue
If your issue persists it is possible that the program, utility or game causing the runtime error may have issues. Verify through the developer's web site that all updates or patches that may be available have been downloaded and applied.
If no patches or updates are available, attempt to uninstall and/or reinstall the program that is causing the issue. If you are having a runtime error in your operating system, reinstall the operating system.
3. Computer virus
Because computer viruses are capable of tampering with the system settings / memory it is possible for a computer virus to generate a runtime error. If you are currently running a virus protection program on your computer ensure it has the latest updated patch or .dat file.
If you do not have a computer virus protection program it is recommended one be purchased or that a demo be temporarily downloaded to scan your computer hard disk drive for viruses.
4. Memory issue
Finally, if you have followed all of the above recommendations, it is possible that you may be encountering a hardware / memory related issue. We recommend that you first contact the developer of the program causing the issue for any possible solutions. If no solutions are found, we recommend you contact the computer or motherboard manufacturer for additional recommendations and/or service.
or
The monitor shuts itself down as a protection feature. Look at the monitor manual if you got one.
Restart the computer and enter Windows Safe mode. Change the settings to a supported setting. Restart the computer so that the new settings take effect.
-Right click the desktop
-Select Properties
-Click the Settings tab
-Click the Advanced button
-Click the Monitor tab
-Select: Hide modes that this monitor cannot display
-Select a different Screen refresh rate
-Click Apply twice and then Click OK
You should also try to modify your resolution.
Hide modes that this monitor cannot display -specifies whether the list under Refresh Frequency will include modes that are not supported by your monitor. Choosing a mode that is inappropriate for your monitor may cause severe display problems and could damage your hardware. You must be logged on as a member of the Administrator�€@trade;s group in order to view unsupported modes.
You should also update your video card drivers and monitor driver if you have one, and try your computer with another monitor and another video card to see if the problem is software or hardware.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
I am not allowed to try any of these solutions because as soon as i start the computer, the message pops up.
