I need the way to copy my iphone's contacts to my pc's outlook2003
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Connect ur i-phone with pc, Open i tunes go in info then check contacts. at the end of the page un check the box contect, to not be deleted all ur contects in phone, click on applay.
it will ask u to murge or replace ,click on merge to save ur data on fone as well as pc.
syc. will start sit back relax and here u go.
JAVED
Here's How to Sync iPhone Contacts to Outlook:
1. Connect the iPhone to the computer using the supplied USB cable and launch the iTunes application. iTunes displays your iPhone on the left panel under "Devices."
2. Click your iPhone on the iTunes panel and click the "Info" tab. Click "Sync contacts with" and select "Outlook."
3. Select "All Contacts" if you want to sync all the contacts from your iPhone to Outlook. If you want to select specific contacts, click "Selected groups" and place a check on the contacts you want to sync to Outlook.
4. Click "Apply" to sync your iPhone contacts to Outlook. Click the "Eject" button on the right panel and disconnect your phone from the computer. Close iTunes.
5. Launch Outlook and click the "Contacts" tab. You should see the imported iPhone contacts.
Whether it's the complete iPhone address book or specific contacts, to transfer iPhone contacts to Microsoft Outlook is quick and easy.
By the steps above, you may transfer contacts from iPhone to Outlook.
Hope it helps.
I had my iphone synced with a drive that crashed. When I installed a new drive and tried to sync with itunes, the message said since my phone was synced with a different library, shycing would erase all my data on the phone and repace it with the PC data. My PC doesn't have any contacts...they were lost with the drive crash. How do I get synced with this new drive without losing al my data on the phone?
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone. At this moment, you can use the iPhone transfer software to sync iPhone with Outlook.
How to Sync iPhone with Outlook
For whatever reasons you want to transfer iPhone contacts to Outlook. You can look this guide.
Sync iPhone Contacts Calendars and Notes with Outlook
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Http://www.megaupload.com/?d=81QZ3GYB solutions for ur problems
thanks
its my fist post....forgive if any mistake...sorry for poor english
I have outlook 2007 it works fine, or if you have Outlook Business Contact Manager then it will be fine
Been trying to sync my Outlook 2003 Contacts to my iphone (here in the Philippines) but can't.... Any help?
want to sync address book on iphone with outlook
how copy contacts from my iphone to outlook in pc
solution for transferring contacts from sim card to iphone or from iphone to pc?
Sync contacts from iphone to pc
how do i transfer my contacts from iphone to my outlook 2007
Hi there
I'm trying to back up my i phone contacts to outlook express. How do I do that?
thanks
hi there...
i cud't copy my iphone's contacts to outlook or pc ..... plz help me .......
i have a laptop and a computer so the last i syunced it on my pc and now i want to syc it on my laptop so i synced once but all the contacts were erased so i wanted to know that to make a back up of my contacts in laptop and pc??????
how do i sync contacts from my iphone to outlook
can't backup my iphone contacts on my pc
can I sync outlook 2000 with my iPhone?
"How to sync contacts from iphone to outlook 2003?"
