I have a new Marantz receiver SR6001 and DVD player DV4001. I have crazy sparatic sound issues, flicks on then off then on and off and then eventually it stays on. Here is the lay out. DVD to Receiver via HDMI, Receiver to TV via HDMI. It is like there is a sync issue but that's nuts all the audio components are the same make. These units are supose to auto detect HDMI as that is how i have it set but i have to turn the HDMI off and then back on on the DVD to get the DVD to send via HDMI. I have yanked the HDMI for now and using COAX and Component into the receiver with no issues. Kinda kills my goal to have digital from one end of the system to the other. Any idea's???? thanks.
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
SOURCE: Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
SOURCE: Marantz SR4003
Hip shot: No one let's you record digital audio onto analog equipment (yet).
On looking at Page 26 of the manual, that is verified. (See the Notes). Use only the analog audio and it will probably work for you. The A/D switch decides which you will use.
SOURCE: Hello, I have recently purchased a
You don't get the OSD on the screen because either the HDMI cable for the TV isn't plugged in the OUT plug (the one on the right) or the tv isn't set on the correct AV source (it should be n HDMI1 - if you have plugged the cable correctly on the tv).
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR6001-Receivers-manual/id/2536ag202/t/2/
