Samsung HT-X250T Theater System Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change the dvd code for a samsung ht-x250
Change the dvd region code for a samsung ht-x250
  • Anonymous Mar 16, 2014
    firmware dvd samsung ht-x250
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 27, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469924
Points
19564
1. Samsung HT-X200 does not switch on 2. How to upgrade HT-X200(2.1) to HT-X250(5.1)
Hi JOHN MATHEW
1.Your Samsung HT-X200, has power supply problems and problems with audio output
2. To convert your Samsung HT-X200 (2.1) to an HT-X250 (5.1), you must add a DSP, several amplifier stages, one for each channel added
You will find it cheaper to replace your Samsung HT-X200 (2.1) with a Samsung
HT-X250 (5.1)
Hola JOHN MATHEW
1.Tu Samsung HT-X200, tiene problemas de fuente de alimentacion y o problemas en la salida de audio
2. Para convertir tu Samsung HT-X200(2.1) a un HT-X250(5.1), deberas agregarle un DSP, varias etapas amplificadoras, una por cada canal agregado
Te va a resultar mas economico reemplazar tu Samsung HT-X200(2.1) por un Samsung
HT-X250(5.1)
https://elektrotanya.com/samsung_ht-x200_ht-x250.pdf/download.html
3answers
I would like to make my SAMSUNG HT-F5500W region free
There seems to be useful info here:
http://forum.videohelp.com/threads/342271-Samsung-HT-D6750w-Region-Free
3answers
2answers
Ht-e4500 region free
None of these procedures work on the E4500 Samsung.
2helpful
I cant play any discs on my samsung ht x200 due to a disc region error
Go through the set up menu on the Ht DVD player (if it's all in one) and change your settings for the region code. Obviously it is not the one that you have already set it to (probably set by manufacturer). NTSC, PAL, etc. I hope this helps.
6helpful
Region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
3helpful
I Need the Dvd region codes for my Samsung HT-TX35 DVd Player
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
