There are two capacitors on the inverter board that will appear slightly puffy on top. Replace both of them. You might also have to replace a surface mount fuse on the other side of the same board. This should fix any backlight or pending problems.
Magnavox 15MF605T/17 15 in. LCD TV Is this inverter board that small board next to the main PCB? and are the two cap purple? Any advice as to what the fuse looks like and where it is located on the back of the board?
badavis,
I have the same problem as cspassik, and have changed out both "puffy" caps and the fuse, but still have a dark screen. Any suggestions? Thanks for your consideration.
This was totally the solution to no picture but normal sound- I purchased the two caps 150uF, 25V. from Digi-key and the tiny 2.5 Amp(or so i think) fuse and voila! Perfect picture is restored for a few bucks. Don't even bother with Radio shack- they don't have the 150. Outstanding solution and web-site. Thanks!!!!
