The wire around the rubber seal on my Bosch Nexxt Essence Washer (WFMC2100UC) has broken, the spring rusted. If I remove the wire can I still use the washer or will it leak ? Also, the rubber seal mildews and smells even though I keep the door open when not in use.
This video will show you how to change a door seal on this Bosch WFMC2100UC washing machine
I have the same washer, and have run it for some time without the wire. As long as you make sure the seal is seated when you close the door, it doesn't leak.
I have no idea about the mildew problem - never had that happen to mine.
