Please keep in mind here that this freezer is 35 years old and it will eventually reach a point where it will be easier to replace it.
All freezers and fridges click, rattle and buzz as they cycle through there job. You only really need to worry if the noise is louder, random or is constantly happening. Some older freezers have a 'Boost' switch where you can turn up the freeze rate if you have recently put a large amount of food into the freezer. Don't use this all of the time as it is expensive to use and can wear out the freezer parts faster. Try flipping this switch and leaving it for 5 minutes to see if the noise changes.
Has the freezer been moved recently? Sometimes if a fridge or freezer isn't level it will make extra noises.
Is the freezer still as cold as it normally is? The noise could be the evaporator fan starting to fail. Get a qualified technician look at it as he will be able to listen to it and give you better advice.
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Does the noise start when you push fast freeze? It bypasses the thermostat. If the green light is out it may just be the light itself and nothing to worry about. Check power to the freezer!
Is the compressor (the football-sized case on the outside back of the refrigerator) making a continuous hum or other noise? A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
If you hear a clicking noise every few minutes, this means your condenser is trying to work but can't. If your condenser coils are clean, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling. I hope this helps!
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
