The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't run at all.
Re: The bucket full light blinks even though it is empty...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
If the water bucket has not been emptied the until will not start. If it has, be sure that the bucket was reinstalled properly in the holder and is making contact with the Water Level Control Switch on the back wall, inside of the bucket holder. The bucket should be installed "squarely" into the holder from top to bottom. The bottom of the bucket should not tilt down at the bottom when installed properly.
I have the exact same problem. I suspect this is the same as the "CH 01" problem others had with a different unit that seemed to be the bucket switch. I still need to confirm.
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
I just now noticed this posting even though it is now November. I will post this in case you still have the dehumidifier & haven't solved the problem yet, or for those who may be searching for a solution later.
The 01 code & the blinking light indicates that the defrost sensor is probably shorted. Replace the sensor assembly with part #6877A30013L. It includes the humidity sensor & defrost thermistor & plugs onto the main circuit board for an easy repair. Sears lists it on their website for 9.99 + shipping.
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
