Brother CS-100-T Computerized Sewing Machine Logo
Posted on Jan 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to thread a Brother cs-100 sewing machine
How do I thread a Brother cs-100 sewing machine
  • Anonymous Mar 26, 2014
    My broth cs-600i will not turn very easy
    my brother cs-600i will not turn very easy
Anonymous
Level 3:
President:
  • Master 405 Answers
  • Posted on Mar 30, 2010
Anonymous
Master
Level 3:
President:
Answers
405
Questions
0
Helped
205371
Points
1407
My brother sewing machine keeps un-threading. I have checked the bobbin and took the thread all the way out and re-threaded it. What else can I do?
Make sure you are using the right needle for the application. Also check that your needle isn't damaged, bent or put in backwards. Sometimes a needle will have a burr on the eye, just sharp enough to break the thread. So always buy quality needles. Check your tension too.
Having problem with threathing the machine and getting it to sew. Please help me. Thank you!
Here is a threading guide I found for you.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
Operation Manual's say, "...Remove the tangled thread....the operation..." So I removed all the threads and still show E6 in the LCD panel!!! Please help.
Did you brush it out? Now, unplug and wait 15 seconds the plug in again. Totally rethread your machine and make sure the thread is not tangled. That should reset it. If not, call Brother at 1-877-276-8437
E-4 error Brother
Error E-4: The reverse/reinforcement stich button, needle position button or thread cutter button was pressed while the bobbin winder shaft is moved to the right
My needle on my brother CS-100 sewing machine keeps getting stuck on the bobbin case. I think it may need to be retimed but do not know how to do this.
before you do that, make sure that the machine is threaded correctly. often when the needle is threaded from the wrong side, the thread is wrapped around the top wheels incorrectly, or the bobbin is not threaded right, it will cause the needle to get jammed in the bobbin. however, if this does not work, check their hotline and ask the maker what you should do. you can also go to a local sewing machine store and have them take a look at it.
2answers
1helpful
2answers
Lost my manual for my Brother CS-100-
Here is a site for the manual. Just click get manual, register for free on the site, then download it. It works great!
2answers
Computerized brother cs 100 keeps untreading itself while sewing
it is not threading properly
indicates that the needle /hook timing is off a bit or the bobbin thread tension is too tight
2helpful
E6 error on CS-100, thread underneath all knotted and tangled, makes grinding sounds.
Your bobbin is not wound correctly. Check and see if your bobbin thread is wound to loose or unbalanced.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
