Dvd tray is locked and i cant find the manual to unlock it.
My four year old has pressed a combination of buttons to lock the disc tray on our dvd player. It is a Sanyo and i have misplaced the manual. I know it must be very easy to get the right combination of keys to unlock it but not having done it before, I must be pressing the wrong combinations at the wrong time.
I have also tried powering it off while holding in the open tray button. I have removed all power including plugs while trying the same thing - no luck!
Any advice or help in this matter would be greatly appreciated.
Thanks in adveance Robbie Stephen
I had the same problem, and I didn't know how I was going to fix it. Thanks. I had the same problem, and I didn't know how I was going to fix it. Thanks.
You can't post conmments that contain an email address.
Re: dvd tray is locked and i cant find the manual to...
Press the open button down for 5 sec and the dvd player will say unlock and then you can hit the open button and the tray will open. I just did this. IT WORKED YEAH!!!!
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened. There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system. Unlocking Procedure 1To turn off the Dealer
Lock function, follow these
steps:
Turn on your Home
Theater System.
Press the Stop button
on the front panel and
the Power button on the
remote control simultaneously
for four seconds.
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2To turn off the Dealer
steps
Turn on your Home
Theater System.
Press and hold the
Function button on the
front panel for 3 seconds.
The display shows the
word Unlock.
Note: Repeating
Unlocking Procedure 3To turn off the Dealer
steps
Turn on your Home
Theater System.
Press and hold the
Open/Close button on the
DVD player on the front
panel for more than 4
seconds.
Note: Repeating
the two steps above turns Dealer Lock on again. Unlocking Procedure 4To turn off the Dealer
steps
Using the HTS remote press the Menu button + 712, and the HTS will display
CAN OPEN.
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
steps:
Turn on your Home
Theater System.
for four seconds.
Note: Repeating
steps
Turn on your Home
Theater System.
Press and hold the
word Unlock.
Note: Repeating
steps
Turn on your Home
Theater System.
Press and hold the
seconds.
Note: Repeating
steps
CAN OPEN.
as well.
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears. The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
