As of January 1, 2010, my HTC Snap will not display the time of incoming text messages. Outgoing texts show the time sent, but incoming texts only show the date. I have tried removing the battery to reset, and that did not fix the problem. Any thoughts?
go to message setting, text message, text meassage HELP NUMBER +1 833 272 0777center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
I have the same problem with my pantech p4070 or whatever this thing is. It also started 12/21 in the morning. It must be some weird network issue. AT&T? Changing the date on the phone to tomorrow slightly remedies the situation, if you can remember that it is in fact, not tomorrow, yet.
try going to menu, settings, date & time, and make sure the information is correct where it says "set date" and "set time." if either is wrong, enter the correct information. that should fix it. what happened is your phone thought you were sending a message earlier or later in time than you actually were, while whoever you're texting was sending messages on time. soooo all of your messages end up clustering at the top or bottom depending on if your phone's date & time is set early or late.
The phone itself does not have an option to make all text larger. For text messaging purposes download the application "Handcent." It is a better text messaging application that gives you the option to increase text size. After installing Handcent. Go into it then go to settings (press the menu button), then custom
style and then bubble settings, then you have options for incoming and
outgoing font - click on those 2 (one at a time) and in the bottom right
hand corner it will give you the option for text size.
Hope this helps!
Also, for webpages, You can just use the pinch and zoom feature. Pinch your fingers together where you want to zoom and pull your fingers apart. That will zoom in on the area you would like.
You need your message centre number for outgoing text messages. You can find the number by going on your networks website or by phoning you networks customer services.
7 day free trial for your services shouldn't cost me the aggravation of providing my VISA Card # and then fighting to undo the charge for free service offered. No - I haven't solved problem of new phone just purchased.
go to message setting, text message, text meassage center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
First make sure your messaging is set up correctly. Make sure your phone is able to get incoming as well as outgoing calls. If you have your restriction only on. You wil only be able to get in coming messages. You will have to contact your network provider and have them make sure your account is set up to receive text messages..........Good Luck! : )
