Question about Sony Bravia KDL-26L5000 26 in. LCD HDTV
My new sony 26 inch bravia lcd tv suddenly loses signal
My new sony 26 inch bravia lcd tv has suddenly stopped showing tv and gone to snowy screen with loud screeching sound. four times in first two days. Turning off/on power clears problem. Once it cleared itself in 3 to 5 seconds. Is it a signal or power supply problem, or something in the tv itself?
    President:
  • Sony Master
  • 1,114 Answers
If it's new, get it replaced. Video board problem.
Posted on Jan 02, 2010
  • Sony Master
  • 1,257 Answers
I have seen this happen in other Flat Screen TVs. (The Polaroid brand is one of them) You definitely have a bad power supply.As you say, shutting off the the TV and turning it back on sometimes stops the problem. First thing to find, are bad capacitors or bad grounds that need resoldered.. This is your best solution, I have repaired many howling and screaming flat screens. Thanks for listening.
Posted on Jan 22, 2013
6ya staff
SOURCE:
I have Sony LCD tv
Any other indications? It looks like it turns itself into 'stand-by' having no input signal.
May 29, 2015 | Sony BRAVIA KDL-46BX450 46 inch LCD HDTV...
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Sep 01, 2009 | LG 26LG30 26 in. LCD TV
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Tuning problem
The tuner is bad. Could also be the video process, since the hi-def is decoded there
Oct 06, 2008 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
Jun 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL 46XBr2 Screen problem
You have a bad LCD panel. Hopefully it is under warranty still as they are expensive.
Jan 10, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia KDL-26L5000 26 in. LCD HDTV Logo
667 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
