Block a number on my Samsung d500
hi,
try these steps, press your call key, it will give you the call log menu, press options, under options, you will see add to reject list, highlight the add to reject list and select the number you want to block.
or you may try to do these,
press menu, under menu, select settings, under settings, select application setting, under application settings, select call, under call, select all call, under all call settings, select auto reject, under auto reject menu, highlight the reject list, then add the number, highlight search and it will give you the following options, call log and phone book, select from the two and search and add the number you want to block, select activation on and select save.
regards..
