E015 •Clock pulses of the pick-up/duplexing/developing motor fails to be generated or be detected.
•Excess current of the pick-up/duplexing/developing motor is detected.
I do not have a solution for that. A Canon printer tech would know what to do to fix it. But you have to weigh the cost of a fix with the cost of the printer.
Description Developing roller release operation defect
After the specified time from rotating the main motor for the developing roller depress/release, the output of the developing home position sensor does not change.
Causes Developing home position sensor defect, Main motor defect, DC controller PCB defect
Remedy • Check the connector of the developer home position sensor, main motor, DC controller PCB • Replace the developer home position sensor • Replace the main motor • Replace the DC controller PCB
A E015 error deals with the fuser drive > from what I remember about it, there is a drive gear on the front of the fuser unit and on the inside front of the copy that are binding up and not turning correctly. They will need to be replaced or cleaned > the error code can not be reset until the problem is fixed.
