Televison & Video Logo
Anonymous Posted on Jan 03, 2010
I have an LCD Samsung TV LE26R86BD I have a manual and set the colour preferences it lasts for about 2 hours and then the screen goes momentarily black and reverts to the previous setting which was dynamic. Can you tell me how to set my preferred setting for the TV permanently. I have satellite, TV from Sky, I have a DVD player linked into the TV also. Viv
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 05, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
323
Points
Moved the telephone and the internet modem away from the TV monitor!!
13yr old Samsung plasma TV 1.when TV turns on shows red remnants from initial screen image. Lasts for 15min then goes away. 2.sometimes top half of screen goes black. Must tap on right side of TV.
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Verticle colour lines
Probably the Tcon board problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience for TCON Board articles.
http://electro-medical.blogspot.com/
2helpful
2helpful
2answers
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
8helpful
MY PICTURE SETTINGS KEEPS RESETTING ITSELF AFTER ABOUT 40 MINS.
I have got a Samsung LE40R88BD 40in lcd tv that after about half an hour the screen goes black and then comes back on after about ten secs but the picture is very much darker. what is the problem?
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
2answers
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
1helpful
Samsung TV , black screen
Check for the timer settings if possible reset to default......
Samsung 40" LCD LE40R74BDX screen flickering all different colour
You either have bad Main bd and or a bad T-Con bd on the Panel. Have a trained samsung tech troubleshoot the set.
Screen flicks from colour to black and white
If it does it only on HDMI, then, the problem is the Main PCB. The HDMI cables are to heavy for flat panel sets. If the problem happens on just one input such as component and analog, then the problem is more than likely the source. Does the problem appear on DVD, but not the cable/satelite? If the problem appears on every input, then the problem is the main PCB. Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
