You have gone through a long way.To check if the hard disk is the culprit. Just Boot the System using any Bootable CD like Linux live distribution CDs or Hiren's Boot CD.If everything work fine than replace the Hard drive or try to repair it.(work in many cases).
I recommend the second one because,it has got many tools for Hard Disk Repair (in case hard drive is the culprit) and moreover if you need to change the Hard Drive.you can always backup the data using the Said Disk.
Here is the download link
http://www.hirensbootcd.net/
Just Click the "Download Button".
and start downloading.
Extract the ISO image file and burn it in a CD and Boot the system using that CD.
Hope will it help you in pin pointing the problem.
Good LUCK.
