It wont fold down nor will the handle move and is stuck with the big wheels stuck at the front ehich is hard to push when walking around town!! the metal frame will not fold down at all!!! please help
Push in the little white button on the frame handle and pull the 2 buttons on either side of the handle - if the frame doesnt fold doew gently move the handle a bit untul you hear a click then should fold
Yes it will fit. the fabric seats are not interchangeable but everything else is. Currently I have Cam wheels on my frog chassis. As well as a cameleon canopy, and a fabric flease set on my frog seat.
This should only happen when the seat/carrycot frame has not been put on. If this happens when the seat is on, then I would suggest that this is returned for a repair (www.bugaboo.com) as this could be dangerous.
hi there are clips you press together on the rear frame just by the wheels and the wheels will slide out very easy. if you nedd any help on bugaboos we are the experts ' www.buggypitstop.co.uk just ask for fred
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle out with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
I have seen this problem before. If the wheel was accidentally crushed or bent while still on the stroller, it may have become bent. This has also occurred while checked on a plane. If the stroller is still under 2 years old, bugaboo will usually replace the piece. If not, most bugaboo retailers sell replacement wheels. You can contact bugaboo here: bugaboo.com
