I have a minolta, 35 mm camera with automati focus, and it is supposed to go to af when u turn it on, but it has quit, i only have manual focus now, any help will be appreciated thx
I have the same problem. I tried everything but for some strange reason even when I try to slide the switch down it wont turn auto focus back on. This happened one day when I put it into manual focus and then tried to switch it back to AF. Any help will be greatly appreciated!I have the same problem. I tried everything but for some strange reason even when I try to slide the switch down it wont turn auto focus back on. This happened one day when I put it into manual focus and then tried to switch it back to AF. Any help will be greatly appreciated!
You can't post conmments that contain an email address.
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
It is because the lense is only an AF lense. The d40x doesn't have an on-body auto focus motor so that needs to be on the lense. I have a d60 and have the same problems. You can use the manual focus on the AF lenses; however, to use auto focus, you need to buy an AF-S lense. It's disappointing I know, but that's the price we must pay for saving on our body lol
The F/stop isn't supposed to change when you focus. Depending on the camera, you change the f/stop by either turning the aperture ring on the lens or turning a command dial on the camera body.
Is the re-wind button stuck in? If so it can be released by moving the take-up sprocket manually. If that did not work there is a broken take up gear. This was a common problem with the X700, a white plastic gear was used at the bottom of the take up spool mechanism that just was not strong enough especially when trying to get just one more shot from the roll of film. No new parts are available.
