Put the brake wire to ground, but remember this is dangerous and you may cause an accident.
The dodge has a motion gyro setuo even with the ebrake on as soon as you move it shuts ott i was told like with a pioneer you need to program deck to set it to bypass mph any ideas on this anyone fixed a dodge to work ????????????
SOURCE: bypassing the brake wire so i can watch video whenever i want
Hello haehner, Question why would you want to watch a movie while driving? That beeing said this is a tech forum so here goes. Take the brake wire attach it to a switch, take the other endof the switch and attach it to ground. In most cases companies have gotten wise to just grounding the break wire, so they have made it so the feature must be keyed off the break pedal light switch and must be connected, if conected to permanent ground it senses this and shut the unit down anyway, so what you have to do is connect the switch as I told you and try the sequence of on-off-on and this will disable the break feature. Again, don't do this the break wire is a safety feature. Thank you, Shuttle83
SOURCE: watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
