Question about Nintendo Wii Console
The pointer or "hands" dont work properly
I just recently hooked up last years wii so i could get the internet on the tv. i believe my version is 3.2. am i able to connect to my wireless router? i am not sure if i have to do anything with my sensor, it is plugged in and the games work fine but the hands or pointers dont show up
    Scholar:
  • 54 Answers
If the pointers don't show up it is a strong indicator that the sensor bar isn't working or connected properly.
I don't think that it has anything to do with internet access but your wireless router should work fine as long as you have a USB wireless access card and then go into your settings and connect the devices, which is an easy process.
Posted on Jan 04, 2010
6ya staff
SOURCE:
Good Morning..we are two senior citizens that are completely ignorant when it comes to anything tech...we have a wii, pc, and wireless internet. The grandchildren were playing wii last weekend and now we...
Well what you need is the name of your wireless internet, the password for it[if you have one set up]. What you would do is head to the options of the Wii. In the options you need to find the button that says internet. The you must pick wireless for the internet, scan for the name of your wireless internet, and put in the password if you have it. Then it should run a test, if you did it right, it'll connect and you should have internet again.
Sep 10, 2011 | Nintendo Wii Console
The wii wont hook up to the internet
Here is a step by step instruction on how to connect your Nintendo Wii to the internet. Please note that you need to have a wireless router, or wireless connection to be able to connect your Wii to the internet because it only has wireless capabilities!
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Sep 04, 2011 | Nintendo Wii Console
How do u get internet on your wii
Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note you will need access to a wireless internet connection, or must have a wireless router in order to connect your Wii to the internet. The Wii only connects via wireless signal!
Cannnot connect to the internet error 50300 0n tv screen?
Hi.
It appears that your Wii console's Internet connection may be affected by wireless interference.
Try the following:
1) The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
2) It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
3) While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. Click on the link below for help
If the problem persists then please click on the below link to troubleshoot any problems.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Good luck.
Jun 09, 2011 | Nintendo Wii Console
How do I hook my wii to my internet
You can hook-up your wii to the internet through any of the below method;
Connect a Nintendo Wii to the Internet through a Wireless Router
* 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
* 2 Press the "A" button on your Wii controller to continue from the warning screen.
* 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to
move the hand shaped cursor over the "Wii" button and pressing the "A" button on the
controller to select the Wii options.
* 4 Click the "Wii Settings" box on the right.
* 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and
"Connection Settings."
* 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless
Connection" option, and the "Search for an Access Point Option."
* 7 Choose the access point you want to use from the list that will be displayed. Save the
settings by clicking "OK." Then click "OK" to start a connection test. When the test is
complete you are connected.
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter
* 1 Insert the Wii LAN Adapter into the USB port on the back of the console.
* 2 Connect an Ethernet cable from your modem or router to the adapter.
* 3 Turn on the Wii console.
* 4 Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by
clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left
of the screen. Choose "Internet" from the list of options.
* 5 Select "Connection Status," then "Connection 3: None" and "Wired Connection."
* 6 Click "OK" to initiate the connection test. When the test is done you should be connected.
Connect a Nintendo Wii to the Internet through a PC
* 1 Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows
XP that is connected to high speed internet. When the setup window appears click "OK" to
start the installation.
* 2 Choose your language and click "OK".
* 3 Insert the connector into a USB port on the PC when prompted. Hook the connector directly
to the PC as ports on the monitor and keyboard will not work.
* 4 Click on the registration tool on the Windows task bar.
* 5 Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii
Settings" option by clicking on the left square. Scroll to list more options by clicking on the
blue arrow to the left of the screen. Choose "Internet" from the list of options.
* 6 Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose
"Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue.
* 7 Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector
Registration Tool window. Click on your Wii's name and select "Grant Permission to
Connect."
* 8 Return to your Wii and click "Next" for the setup completion window, and then click "OK" to
run the connection test.
Good luck.
Apr 19, 2011 | Nintendo Video Game Consoles & Games
Wireless intermittment so no internet or whatsapp has worked well up until last night when it just did not connected. Correct wifi name but no connection.
The free version of Whatsapp is a one year license. If you've used it for more than a year, you'll need to pay for it. Its $1.99 a year I believe.
Cheers
Mar 15, 2011 | Apple iPhone 3G
How i hook up my wii to my wireless internet
To connect your Wii via a wireless connection:
Go to the Wii Menu.
Click on the round Wii button on the lower left corner.
Click Wii Settings.
Click the right arrow to go to page 2.
Click on the Internet button.
Click Connection Settings.
Click Connection 3.
Click Wireless Connection.
Select Search for Access Point. Click OK.
Select the access point you want to use. Click Save and OK.
You may be prompted to enter your password.
Your Wii should now be all connected.
Feb 27, 2011 | Computers & Internet
My wii sytem and associated tv are located 3 rooms away from my router. I have a wireless system through Comcast. I want to hook up to Netflix, got a LAN adaptor, was told that I could do it without an...
As long as your Wii can detect the "network" in your house, you can connect to the internet, and hook up to netflix wirelessly. Start your Wii and go to "wii options" in the lower left corner. Then click on Wii settings and then scroll to page two. Then click on "INTERNET". You will then go to Connection settings. From there choose wireless and let it find your router. You will need to enter the "passphrase" for the router, to connect. SAVE your settings and each time you start the Wii it will automaticly connect.
Jan 15, 2011 | Nintendo Wii Console
How do I re-set my wii password?
On the Wii console's main menu, click on the 'Wii button' in the lower left corner, then 'Wii Settings' then 'Internet' button, Select 'Connection Settings' you should see your wireless connection and be able to edit the password or just set-up a new connection by choosing 'connection 3'
Mar 01, 2010 | ASUS Eee 4G Notebook
Nintendo Wii Console Logo
76 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
