Our whirlpool front loading washing machine is leaking water from the front door. Is this something we can fix?
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
