SOURCE: Maytag Dryer DE210 wont start
This fuse is often mounted within the exhaust duct in the back panel. It is about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced.
Good Luck and have a nice day.
SOURCE: Maytag electric dryer Model-Pye2300AZW did
The air flow past the thermal fuse is too hot. The air flow cools the heater coil area. Check the air passages from the lint filter to the heator coil housing for lint balls blocking the flow and letting the area around the fuse get too hot.
SOURCE: LE GQ8000HQ Whirlpool Ultimate II Electric Dryer
Copy and paste the below URL into you address bar. Go to last page.
http://www.kitchenaid.ca/assets/pdfs/literature/Repair%20Part%20List%20-%208180403.pdf
SOURCE: Maytag Performa PYE2000AYW Dryer.
YES, MAY NEED TO RESET MOTOR TO BLOWER OR CHECK HEATING ELEMENTS
MAKE SURE THEY ARE NOT BURNT INTO.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
