I am having the same problem date and time search does not work, it just always goes to the begining of the hard drive.I am having the same problem date and time search does not work, it just always goes to the begining of the hard drive.
AnonymousMar 01, 2009
same thing --always goes back to earliest time i never want to see .. I can't get it to accurately search out requested time and date.same thing --always goes back to earliest time i never want to see .. I can't get it to accurately search out requested time and date.
You can't post conmments that contain an email address.
It does the same thing to me....Can you imagine sitting there viewing the whole hard drive just to see what happen 39 minutes ago. This Samsung DVR is stink.....believe me ...Every problem I read on here,,Im have the same..
There is a small fan in the back of the unit which might be rubbing or failing. It's a standard type of fan so any good computer parts store will have a comparable replacement. Or it could be the hard drive is beginning to fail. You will have to open the case to find out.
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key : Mode Key + CH 2 •The Password and all setting value will return to the initial default value. •Default Password is ‘4321’ .
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
The manual says: You cannot enter MENU by forgotten password. - If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to the values set at the factory. Keep pressing both the "MODE" button and the "PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button and the "PTZ" button on the left for 5 seconds. The password default is "4321".
try resetting the system and reprogramming if that does not work you may nee to find a factory authorized repair facility in your area.
I'm wondering if the firmware can be upgraded as that might be the easiest thing. My other thought was that putting the hard drive into a PC and trying to view the video might be a way to see it.
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice
use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded.
Good Luck!
