You should copy ALL pictures from your memory card to your computer and then format the memory card USING YOUR CAMERA (don't format it using your computer) That should empty your memory card and can be used again as if it is new.
If you are still experiencing the problem/issue reply here and and give some more informations regarding your problem (such as the capacity of your memory card and the settings of your digital camera)
You can rate my answer if you appreciate it. Thanks!
Hello Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Memory card likely has temporary(needs formatting) or permanent problems(needs replacing, common for off branded china junk).
First format the mem card on your camera by pressing center Menu button then scrolling down to the end of the menu to Format. If this does not work, and you have bought a Name Brand SD card; Sandisk/Kingston/Patriot etc, return it to place of purchase with receipt, or creditcard use to purchase it, and they will replace it.
