My childs Leapster 2 will turn on but when she tries to touch the
screen with the pen it wont do anything. Can this be fixed or do I have to go and buy a new one?
You need to calibrate the touch screen - hold down the ? button and a menu will come up, go to 'touch/calibrate'-red dots will appear on the screen in the corners then in the middle and you have to touch the centre of them with the pen to line up the screen again - turn off and again and it should be fine - hope this helps xx
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
We have the same problem and our leapster is only 2 days old.Do Touch
Screen Calibration,it should help.I do it everytime for my son when he
wants to play and it does help...But once u turn leapster off,u'll have
to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu
screen appears,press the A button.Touch each of the crosshairs that
appear with the stylus.restart unit. ..That what we do everytime.
Answer I had the same problem and here is the answer I found
at leapfrog.com which fixed my daughter’s disney princess leapster 2’s
problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to
hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
1) Ensure that a cartridge is not inserted2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.3) When the LEAPSTER menu screen appears, press the A button4) Touch each of the crosshairs that appear with the stylus5) Restart unit
I found out how to re-calibrate it. By holding down the 'hint' button while turning it on then choosing the 'touch calib' option...you then have to touch the bullseyes on the screen. Turn it off and back on again and it should work.
you should try this. I did and it worked perfectly
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
