The ones highlighted in pink are not supported for your motherboard, the ones highlighted in orange may or may not be, and all the ones in white are compatible with your motherboard. It looks like you have several high-end options, up to 2.8 GHz.
You can download the motherboarddrivers and BIOS updates from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system.
Please click on this link andselect your model motherboard : -http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
hi there is a way of doing this but its a bit of a pain, you will have to create a customized windows xp disk which is quite involved, i had the same problem as i have a new laptop and it had vista on it but i preferred xp you have to get a program called nLite that you can create a image file of the original windows cd and then add your laptop specific drivers for the sata controller as i gather this is not a very old laptop such as mine, windows xp does not recognizesata drives as boot drives, you can download your drivers from gigabyte and insert them into the windows disk image, there is comprhensive instructions in nLite on how to do this, and it is quite simple even for someone with hardly any computer knowledge....hope this helps
1.Vista is considered an upgrade, compared to Windows XP. Therefore, Vista is not just going to let you install over it.
2.You have to get your Windows XP drivers back.
This is a pretty intricate operation, but once you have detailed information, it becomes do-able. Below is a link with detailed information, and concise clear illustrations. I felt it would be better to give you this link, to avoid any confusion, and/or misunderstanding of information from me.
I'm not sure that 845 is the right identification for that motherboard, but Gigabyte has a terrific site for downloading HERE. You will need to answer a few questions about the motherboard but I'm sure you'll find what your looking for.
Try this. Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
