This looks like the Heath Zenith SL6162/63
(http://www.1800doorbell.com/db800-wireless-battery-chimes.htm#SL6162)
I have the pdf of install manual if you would like it. This wireless doorbell has over 128 codes that prevent outside interference. Here's part of the manual for changing the code:
Note: Most installations will not require you to change any of the jumpers
on your doorbell.
The doorbell button and chime communicate by using a code that can be
changed by removing and/or adding jumpers on both the doorbell button and
chime. The code is factory set; however, there are 128 selectable codes that
allow you to expand your system and prevent outside interference. Another
wireless doorbell system or other wireless products may cause interference
and the system may not function properly. Follow the instructions below for
setting a new code.
1. Disconnect the power to the doorbell button and chime.
2. Open the cases and locate the jumpers on both the doorbell button and
chime (See illustration).
Attach the back of the
case to the door jamb or
wall. Snap the front of the
button back on.
Holes for
Wall Mounting
595-5611-06 - -
Battery
Battery
Battery
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Doorbell Button Battery Replacement
Install an alkaline type A23 12 Volt battery. The
positive terminal should be positioned as shown.
* Code Settings 1-7
Must Match Both
Doorbell Button and
Chime
Inside
Doorbell
Button
Inside Chime
3. The doorbell button and chime both have eight different jumper locations.
The jumper positions 1 through 7 are used for setting the code.
4. To change the code, add and/or remove jumpers as needed. There are 128
different combinations. It is recommended to only change one jumper at a
time and then check to see if system is functioning properly. Note: Jumpers
in positions 1 through 7 must be exactly the same for both the doorbell button
and chime for this system to function.
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
