Question about LG GSA-H22N DVD±RW Dual Layer Burner
DVD writable media not recognized by drive... shows up as "Blank CD"
I'm using Windows XP Pro SP2, and when I try to use DVD+R or DVD-R, the media is detected as "Blank CD". If I try to copy files into the drive window, it gives a generic message "Error Encountered".
I went into device manager and removed the drive, then re-discovered it, but still doing the same thing...
Any suggestions?
Thanks in advance,
Clark
  • 2 more comments
  • ilovesuri Mar 13, 2008
    i have a sony vaio laptop with a MATSHITA_DVD-RAM_UJ-850S
    it works normally with dvds (reading and writing) but when i insert a cd it always shows it as blank !
    what could be the problem with it?
  • Anonymous May 03, 2008
    I've got the same problem as well when i insert a blank dvd-r it shows up as a blank dvd i have updated firmware and reinstalls etc but still the same thing it recognizes dvd movies but not blanks
  • adityab May 29, 2008
    I have the same problem. My drive shows my dvdr's as blank, ive checked it oin another computer and the dvd's working
  • weitzmanN Sep 26, 2008
    I see the same with my IBM laptop and Matshita DCD+RW. No burner can see the blank DVD placed in the drive. It seems that most of the computers where working and in probably because of an M.S update something has been corrupted.
    Please Help! it happens also with Vista business.
Lol a blank DVD cant be opened directly in Win xp, you need to use a DVD burning tool... for your laptop did you check you the DVD-ram reads cd's also?
Posted on Jun 14, 2008
I am using a Lenovo Y500 laptop with Matashita drive. When i insert a CD the autorun shows it as "Blank CD". Also the drive is not able to write on recordable media.
Posted on Oct 23, 2008
6ya staff
SOURCE:
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
My DVD player can't detect DVD CD file, but it can play CD. i've tried to check on the device manager and its working properly. i also have tried reinstalling its driver but still not working... i am using...
i have faced this problem in my case DVD was working and cd not you problem is the lens of you cd/dvd drive has become worst and cant work any longer it needs to be replaced. Hopefully it might have helped you.
Jun 19, 2010 | Microsoft Windows XP Professional
Using Windows XP. Want to copy vidoe from Media
Is the drive you are using a DVD writer or only a DVD reader? The drive that writes to RW disks is labeled DVD/RW or DVD Recordable.
These are the only drive types that will read and write a DVD/RW disc.
Jan 04, 2010 | Acer Aspire E500 PC Desktop
I download video from my flip video, but I cannot burn to DVD-RW...it says to insert CD which I have already done
What CD are you using to Burn then movie?
Get a Blank DV Rewriteable CD (make sure its blank)
Format the DVD CD by right clicking it from Windows Explorer and follow the instructions. (this should not be neccessary especially if its a blank CD)
Use a normal copy and paste from Windows Explorer to copy the movie file or folder into the DVD drive.
this process absolves the issue of media formats and portability. Also most CD DVD Burning Softwares are not compatible with some players.
May 15, 2009 | Microsoft Windows XP Professional
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Windowz format problem????
just try with another cd disk
Mar 16, 2009 | Samsung X05 Notebook
Sony VAIO model SZ330P notebook. How to create Startup CD
One easy way to make a startup CD: In your c:\ drive, find and copy the folder named "i386" to a blank CD. That folder is in c:\windows You might wish to use a CD-RW so that you can overwrite in case you make a mistake. You'll also need to find and copy these three files: regedit.exe, expand.exe, and winnt32.exe. These are also in the c:\windows folder. Keep in mind that if you have to use the disk someday, you'll need your XP product code, and you'll have to go into the BIOS and set the computer to boot from CD/DVD. Hope this helps.
Feb 27, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Problems copying a folder
eject the cd/dvd from cd-room and start copying .. when copy is finished put cd/dvd in cd-room and write these files to cd
all above actions done without any prgrams with Xp sp2
regards
zoser
Oct 20, 2008 | Microsoft Windows XP Home Edition
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
LG GSA-H22N DVD±RW Dual Layer Burner Logo
3,987 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
