Use a putty knife to open the top lid and fold it back. Locate the lid switch. Unplug the washer. Remove the wires from the lid switch. Use a volt meter set for continuity and test the lid switch terminals. If they are open,no reading replace the switch. For a test you can jump the lid switch wires together,set the washer to spin and turn it on. If it spins it confirms a bad lid switch.
Copy and paste this link for a lid switch picture.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-cw5000-%3d%3di1456&PartID=1456
Sounds like you have a motor issue, listen when you press the start button, if you hear any squealing noises or any of the noises the system usually makes doesn't occur, then you probably have a motor issue, you may need to have your motor replaced
