Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2. Enter *#865625# then the 16 digit unlock code
3. Device should say: Network Lock Deactivated
4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card
Power on the handset - phone will display "phone restricted"
Select "Cancel" - phone will display "phone restriction code"
Enter the SIM Unlock code.
Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card
2) Type *#865625#UNLOCK CODE
3) Press OK
4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone;
2) The phone display: Invalid Smart Chip
3) Power on handset
4) Select "Cancel" - phone displays "phone restriction code"
5) Enter the unlock code (8 digit code*)
6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card"
2 - Power on the handset - Phone will display "Invalid SmartChip"
3 - Phone will display "Invalid SmartChip"
4 - Enter 159753#*#
5 - Enter the 8 digit SIM Unlock code
6 - Select "OK"
7 - The handset is now successfully unlocked
Model : LG CU500
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
4 - Enter the 8 digit SIM Unlock code
5 - Select "OK"
6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card"
2-Power on the handset - Phone will display "Invalid SmartChip".
3-Enter *#865625# then select option 1 and then again select 1
4-Enter the 16 digit SIM Unlock code
5-Device should say: Network Lock Deactivated
6-The handset is unlocked.
7-How to Enter Unlock Codes on CU575 (Trax)
How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#.
2-Handset shows saved, then return to startup screen
3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4-Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2-Select 'Sim Unlock' menu #
3-Enter NCK code then validate
4-Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*#
2-Shows test menu
3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4-Handset shows 'Enter NCK'
5-Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2-Enter the code
3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
If your cell phone is not listed, please follow instructions for LG C2000 above
If
If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Where I purchased the unlock code from they told me I need a not allowed sim card. I don't have one? Is there another way to use the unlock code?
