Watches Logo
Anonymous Posted on Jan 05, 2010
My Stauer Atomic won't stay connected to time signal
I received my Stauer Atomic on Christmas Day. The tower symbol has always been ''solid'' since then. It has seemed to work correctly until yesterday.
Sometime yesterday the tower symbol disappeared. I may have lost the signal traveling through the Poconos. When I got home I followed the directions for seting the time.
I press the button for more than three seconds and the hands go to twelve. Then I press it again, and the hands find the correct time. The tower symbol flashes. However, after maybe 15 seconds the tower symbol again disappears.
My understanding is that the tower symbol should always be present. Any help you can give will be much appreciated.
  • Anonymous Jan 05, 2010
    Thanks. I agree that that makes sense, but I am not sure that the watch is actually checking. The instructions that came with the watch are poor, but they seem to indicate that the tower symbol should always be present. I don't know that that means it is constantly checking the time, but at least capable of checking the time. Otherwise I am not sure that it is ever checking. If I am wrong about that, I would be glad to have some one explain how it works.
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 05, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290826
Points
7081
These watches only need to see a signal several times a day, not necessarily continuously.
If it keeps good time, don't worry about it.
How do you reset the time after changing the battery in a stauer 11475 atomic watch??
Take a look at http://www.stauer.com/pdf/17468.pdf
I see that this watch gets it's time signal from Boulder, Colorado so it will only work properly in North America. Perhaps they also do models for the European market - if so I would expect them to work in the same fashion so the manual should still be relevant.
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
15helpful
Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
G-Shock Atomic Solar watch - ERR in atomic time keeping
The watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
1helpful
Will not recieve atomic time.My other casio atomic
This watch will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it's self change location in your house. It receives the signal at 0200 0400 and 0600 for the correction.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes2_bing.gif and is best received at night.
Hope this tip helps
David
I have several of the both watches and clocks and love them.
1helpful
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
My stauer atomic signal watch won't set correct time
Casio WV58A-9AV Atomic Watch Signal Symbol
When the logo is not shown in the bottom corner, the watch hasn't got a signal yet. put your watch on a window sill, and hold the Forward buton until the watch says GET! Form there, the watch will either display ERROR, if it couldn't find a signal, or will have the latest and most accurate time. The watch is also probably set up for auto detect, which is best. To do auto detect, before going to bed, the watch will try to get a signal from 12 midnight, to 5 in the morning.
2answers
Reset my G Shock watch
try http://forums.watchuseek.com/forumdisplay.php?f=17
seems pretty extensive.
you either need to set your time manually if you are not automatically receiving the atomic signal. if you are receiving the signal, then either you are not in auto DST mode or your home city is set incorrectly.
Nov 08, 2007 • Watches
Top Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Watch Expert? Answer questions, earn points and help others
