You will have to have the jazz board replaced . very common problem . i have one in my own home . . this is the main control. and the only correction . A Maytag problem .. new boards have been revised and do not have the problem .. **** ,. have been doing maytag since 1950 's // hope this hepl.s if your do this service your self ( read the instructions good . as when your finish you wll have to program the control for your model .. **** . .its a easy job but you have to finish it properly.. mm
ok the control board kit ( jazz) is part # 12868513 - you can see this brake down at www.apd.com. when it comes up put go to maytag and put model # in and it will take you to the parts and diag . hope this will get you going .. ****
regarding the "jazz board" would you have the part #, I am mechanically inclined, would I find the procedure in the manual or somewhere else, regarding the insulation and programing of the control?
