<p>Windows Vista administrator password is the password to an account configured with administrator level access in Windows Vista.p>
<p>There doesn’t actually have to be an “Administrator” user account. What you need is the password to any account that can act as an administrator.p>
<p>You may need an administrator password in Windows Vista if you’re trying to run certain types of programs or access certain <a href="http://www.passwordunlocker.com/products/wpu.html"><strong>Windows Vista password recoverystrong>a> tools.<span id="more-121">span>p>
<p>Follow the steps below to quickly find the <strong>Windows Vista administrator passwordstrong> in Windows Vista!p>
<ol>
<li>Try leaving the password blank. If there is actually an Administrator account, the password may not exist at all!Just press <strong>Enterstrong> when asked for it.li>
<li>Enter the password to <em>yourem> account. Often times, depending on how Windows Vista was setup on your computer, the user account you use every day will also be an account with administrator access.li>
<li>Try to guess your administrator password. If, as I mentioned above, your account is configured as an administrator but you’ve forgotten the password, you might be able to guess the admin password.li>
<li>Have another user enter his or her password. If there are other users that have accounts on your Windows Vista computer, one of them might be an administrator.If so, that other user can grant you administrator privileges after logging in.li>
<li><a href="http://www.passwordunlocker.com/products/wpu.html"><strong>Recover the admin passwordstrong>a> using a <strong>Windows password recoverystrong> tool. One of these free <strong>password recoverystrong> tools could recover or <strong><a href="http://www.passwordunlocker.com/products/wpu.html">reset the administrator passworda>strong>.li>
<li>Perform a clean install of Windows Vista. This type of operating system installation will completely remove Windows Vista from your PC and install it again from scratch, removing all your data in the process.If you’re just curious about your admin password then obviously don’t do this. However, if you’re needing the administrator password because of a last ditch effort to save your PC, a clean install will work.
<p>Please note that it is a time consuming process due to the fact that all of your programs and saved data must be backed up and then restored.
p>li>ol>
<p>Reference:<a href="http://blog.passwordunlocker.com/tips-to-find-the-windows-administrator-password/"> How to find Windows admin password?a>
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
Unlock Windows Vista Password is easy!
You can see this article: Vista Password recovery, a workable method. hope can help you!
Don't be worried about that. Lots of people met situlation before. I think the Windows password Rescuer can support your Windows 7/vista/xp/2003/2000/2008 password reset. Use the tool you have 3 choice:
You can log on as administrator on safe mode.If you donot have the admin password,you have to reinstall your windows.
In consideration of remaining all programs and data of the computer,I recomend you to use a passowrd tool:Windows Password Rescuer.It supports all versions of windows operation system.Recover Windows password without lose anything.Here are the simple guide:
Step 1: Download Windows Password Rescuer Professional and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows password successfully.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows when you can not find target user. With this New user account you can logon your locked computer directly to copy important data from the locked computer if you want to reinstall your Windows system at last.
http://www.daossoft.com/documents/quick-start-guide-for-using-windows-password-rescuer.html
Once you forgot admin password in windows vista, you can unlock windows vista password with third-party password reset tools, take Windows Login recovery for Example, it is professional software woking for windows vista password reset. You can download it and follow its guide to burn a password reset CD/DVD or USB falsh drive to get your password reset or bypassed.
Reset Forgotten Windows Password by Windows Password Buster Step 1: Download and install Windows Password Buster Professional in any accessible PC. Note: Windows Password Buster Professional can backup the Password Storage File before clearing the password. The backup allows you to restore your computer to the state before removal.
Step 2: Run the application and insert a bootable CD/DVD or USB Disk in the PC and burn an ISO image file to the CD/DVD or USB Disk.
Step 3: Insert the burned CD/DVD or USB Disk in your locked computer.
Step 4: Remove forgotten Windows password with the burned CD/DVD or USB Disk
Such kinds of questions are often asked on Yahoo Answers and other relative forums. In fact, Recovering Windows Vista password is not as difficult as someone assume. I highly recommend one program named Vista Password Recovery which is the most efficient yet economical one I tested. It enables you to reset Windows Vista password without a sweat. What's more, it is easy enough for all levels of computer users, even novices. Below is the tutorial on how to easily recover Vista Password with this Windows Vista Password Recovery: This tutorial is split into two parts, because the whole process will be accomplished on two computers.
Windows Password Unlocker can recover Windows admin password for Windows 7/XP/Vista/NT/2000/2003....
I used Windows Password Unlocker to reset Windows Vista password. Windows Password Unlocker is a professional Windows password recovery tool for those who have lost or forgot Windows passwords including Windows Vista password, Windows XP password recovery...
