The reason for these lines is your shutter sticking or not firing at all.
The video function should be unaffected due to it not using the shutter and is the easiest way the determine the fault.
What causes it is moisture residue building up on the shutter leafs.
On this model if camera it is quite difficult to rectify because the shutter mechanism in side the lens is a sealed unit. It can be done however but takes longer than other models of fuji camera because of this sealed unit.
Cheapest option would be to find a second camera for donor parts. Even if it is damaged you can still remove the shutter mechanism and swap it over.
