The ground under one of the feet may have collapsed.
The drum may be loose.
One of the springs that support the drum may have broken.
Check the machine by just trying to wobble it on it's feet, this way you can tell if it is firmly on the floor. check that the machine is level
Look down on the drum against the body and see if it is central to the frame and just get hold of the rim and try to give the drum a shake and see if it is loose, these machines always shake a bit because of the design, they are normally used in nursing homes etc in the uk
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
