2000 GMC Sierra Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 gmc 1500 sierra heater control stuck on
2004 gmc 1500 sierra heater control stuck on defrost
Anonymous
Level 3:
President:
  • Master 1,509 Answers
  • Posted on Jan 06, 2010
Anonymous
Master
Level 3:
President:
Answers
1509
Questions
Helped
617690
Points
4704
Defrost is the default position. Is the control a autyomatic temperture control unit? ( you set the temp and select automatic) if it is the system is completely electronic. You push the buttons and the control still says defrost or can you select something else and the control shows it but it just keeps coming out the defrost? If the control changes and the air comes out the defrost anyway and the cheack engine light isn't on, then the problem can be blown fuses or an air door actoater not working. Does the dash emit a clicking sound? if it does with the covers off the bottom of the dash reach around touching the different pieces till you touch the idem that is clicking. this is an acutor motor, or blend door motor. they have gears in them that wear out and break the motors aren't repairable and you just replace the ofending motor. the door that is moves can be stuck. and may have to be freed up with blaster, WD40, or other rust buster till it moves easy. maybe after getting the door to move smoothly you can get the old motor to move the door wiithout having to install a new one.
1999 gmc sierra no heat in defrost but heater and A/C work
Is this a new body-style 99? The electric motors that control the doors inside your heater unit are prone to failure. Your best bet is to have a qualified technician take a look at it. A good scanner will show which motor is bad.
Where is blower motor fuse located in 2007 gmc sierrra 1500
where is the heater and defrost fuse in my 2007 gmc sierra 1500
Heater only blows cold air 2004 gmc 1500 SLT then will work and then stop. vent controls and ac work fine
Check your rad and make sure it is full. Wait til truck is cold before removing rad cap.
1helpful
2000 GMC Sierra 5.3L. Heater is stuck on full heat. It is not responding when I turn the dial to make colder.
sounds like you have a bad actuator motor that is what moves the door in heater box to change from hot to cold
2006 gmc sierra , heater actuator
CHECK WITH DEALER, THIS IS A WARRANTY ITEM. BAD FRON FACTORY ON ALL TRIL BLAZERS, ENVOYS, AND DENALIS.
6helpful
2000 gmc sierra 1500 5.3 v8. a/c heater control problem
your heat/cool and vent selection options are controlled by engine vacuum through small clear tubes attached to the rear of your climate control interface. Other vehicles have small steel pull wires that operate the desired changes. You might try removing the trim and any fasteners affiliated with the interface/console. GENTLY pull outward and look to see if any of these tubes are pulled off or cut/damaged. Did anyone recently install a new stereo in the vehicle? If so, the vacuum tubing and or pull wires that change your outlets could have been damaged when the stereo unit was pushed into place. Hope this helps
1helpful
A/c and heater only blow air out of defrost
either a vacumn pipe is broken or the ends split so its not passing a vacumn to open the flaps,where they are and how to get to them i cant help because i have never worked on one as they are not here in spain.check the engine end first though .Look for some small rubber pipes running from the inlet manifold
1helpful
2answers
sounds like there is a vacuum leak, possibly under the hood.. Vaccumm is needed to change the mode doors.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
