What is the control panel button sequence needed to initiate the monthly bleach cleaning cycle onth he4t?
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
6. Add liquid chlorine bleach.
-open the door and remove the items from the washer.
-continue the cycle by pressing the START button.
NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
NOTES:
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
I am a tech in the appliance industries. No clean cycle is available for the HE4t. Put the washer in sanatary cycle and drop an Affresh tablet. Keeps the door open and dispenser tray open to minimize the mildew smell in between wash loads. Clean the rubber seal and glass every other day. Also pull back on the rubber seal to check for items of clothe that get trapped inside the small gap area.Total time to do this 5 min.
There is none you just put bleach right in the yub run on hot water load i also suggest to put 1/2 cup cascade dishwasher detergent in also some models of the he4 do have a cleaning cycle which you do not have
when i get to the 'push the "end of cycle" signle button 4 times withint 5 seconds' step - nothing happenes for me. Kenmore HE4t
I am a tech in the appliance industries. No clean cycle is available for the HE4t. Put the washer in sanatary cycle and drop an Affresh tablet. Keeps the door open and dispenser tray open to minimize the mildew smell. Clean the rubber seal and glass every other day. Total time to do this 5 min.
From the manual that came with my HE4t:
Select Rinse & Spin button
Select low spin speed
Select warm/cold water temperature
Select 2nd rinse option
Push end of cycle signal 4 times within 5 seconds
The washer will begin the cycle and after about 3 minutes will give 4 short tones
You should add bleach at this time. 1 cup if the first time in a while. 1/3 cup if regularly maintained.
Yes the HE4t does have a clean cycle. Use the direction above to get it to activate. But do not add the bleach till it says to add the bleach. This will read ab on the display.
I am also a appliance technician and own a HE4t washer.
