Samsung LN-S4692D 46 in. LCD HDTV Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
46" LCD Samsung TV Model# LN-S4692D I have no picture
I have a 46" LCD Samsung TV Model# LN-S4692D I have no picture but I have audio. Picture just went out last night for no reason. I haven't had any problems with the TV till this point.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jan 07, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366180
Points
33650
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Hi, i have a fairly new samsung 46" tv with sound but no picture
Please check in dark room condition if you can see the light come up in the background of the tv LCD. If you can see light it would be a T-Con board or main board problem. I think those tv had some issues with the T-con board.
Search results for ln s4692d
Sound with no picture
More than likely it is the T-CON board that went bad in your television set. Fairly easy to replace yourself you can buy online on ebay. Search T.V. model # followed by T-CON and one should be available. There are many youtube videos on how to replace step by step. GOODLUCK!
Samsung, no picture or sound
The power supply regulator board to your tV should be troubleshooted. Sometimes, it might have to be replaced as card basis. Seek tech support.
Snowee picture
If it occurs on ALL inputs then unfortunately the TV has developed a fault. If it is new, it should be returned for a replacement, do NOT accept a repair at all. Be firm and polite, but get a replacement, this is in "Unmerchantable" condition. Otherwise you should get a "Quote" for a repair, do not allow to proceed with out one.
1helpful
Samsung 32" LCD tv, No picture with audio
i will first resolder all ic`s and connections,especiall on the crt board,clean around the flyback at the abl circuits,check for open or changed valued resisters in abl circuit and the video b+ on the crt board (usually 165-200 volts) check also the screen voltage (G2) volts,should be around 250 - 400 volts.
1helpful
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com [email protected]
Hi I have the same problem with Samsung LN-S4692D, which phone number did u call?
you need a T-con board, if there is no backlights at all it could be the power supply
Sound but, no picture
it could be the main, x or y, or buffer board
2answers
LCD TV
I had a problem with a Samsung 46 inch LCD and it had audio and dim light but no picture and found out that the logic board toward the top (inside tv) was bad and was no longer available and the only way to fix it was to get the entire display panel (the logic board came with it) It was not costwise to repair. Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
