Bosch & Tankless LP Hot Water Heater  Logo
Posted on Jan 07, 2010
PowerStar. Model 45-557701 tankless water heater water wont get hot...it slowly quit getting the water hot
Gary
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 30, 2012
Gary
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10936
Points
Hot Water Hot to Cold And back. I had that problem for 2 years. I had a very large shower head from the time I installed the tank-less hot water heater and the water temp would change from one extreme to another. Over time my shower head had stopped working as well as it did so I bought a smaller shower head and installed it and amazingly my water temperature quit changing temperature. I now turn my water to what temp I want and it stays there. It's been working correctly for 6 months now ... until yesterday and it quit working completely which is the reason I'm on here. lol
Anonymous
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Feb 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
10936
Points
I have had no hot water and have fixed it by removing the inlet screen and cleaning it, also make sure the water flow thingy is spinning in the clear inlet side of the heater. If your on a well or have questionable water algae can affect the flow indacater very gently tap the clear plastic while you have the hot water flowing only if it not spinning . It fixed mine. I ended up dumping bleach in my well to fix mine. Hope this helps someone, nothing like getting ready to go to work and having no hot water!
  • Anonymous Feb 25, 2013
    Your solution worked for me. last night had no hot water. After seeing this post took a look at the flow meter and saw it was not turning. fixed the problem by tapping the flow meter.
4 Related Answers
A
Anonymous
  • Posted on Apr 03, 2011
SOURCE: I have a PowerStar model
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Anonymous
  • 248 Answers
  • Posted on Nov 06, 2009
SOURCE: We have no hot water
diaphragm valve or micro switch best of luck
Anonymous
  • 37 Answers
  • Posted on Jan 26, 2011
SOURCE: i have the bosch
how is heating element ? Wasit on with no water running thru it. Does it have a reset?
Anonymous
  • 414 Answers
  • Posted on Oct 07, 2011
SOURCE: Hi I need a installation manuel on a bosch hot
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
AE-9.5 Bosch Tankless Water heater - no manuel or installation instructions
This is a "point of service" tankless water heater that was manufactured by BOSCH. BOSCH is now Bosch-Climate.us. Technical support is available at 866-330-2729. P.S. check this site: http://tanklesswaterheaterz.com/bosch-ae-9-5-powerstar-1-5-gpm-point-of-use-indoor-tankless-electric-water-heater-reviews/
I just replaced the circuit board, and the water gets warm, but not hot.
Problem might be crossover from failed single-handle faucet cartridge:
http://waterheatertimer.org/Crossover.html
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Our PowerStar PS19T tankless water heater
The PowerStar AE115 unit replaces the PS19T model which has been discontinued. Now's the time to upgrade...
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
