How can I block *all* torrents traffic with a Cisco 5540 ASA firewall. It consuming too much bandwidth
  • 1 more comment
  • Anonymous Jan 07, 2010
    HEllo, did you understood the question,
    am in a cooperate network as a Network Administrator and I dont want people to user any torrents,
    So iz all torrents use port 21??
  • 4,281 Answers
First access your firewall.
Then go to NAT then Block port 21 ftp tcp and udp for torrents.
You can also set open port only for needed services and othres are block.So nobody can use anything which not need for your networks.
Block ports 21 ftp for torrents then save settings and restart firewall.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jan 07, 2010
  • Torrents use ports from 6881 to 6999.
    So you need to block those all.
  • 3,230 Answers
Well you can use the torrent software to not allowing more bandwidth, just open the torrent software (utorrent, bittorrent etc....) right click on the downloading file then goto the bandwidth allocation menu and select low bandwidth, just do this with all of the downloading things......
Good Luck!!
Thanks
6ya staff
SOURCE:
I want toblock web sites on my cisco asa 5510 firewall
I know that iKeyMonitor can also block sites on iPhone/iPad/iPod now.
http://ikeymonitor.com/
Jul 16, 2012 | Cisco ASA 5510 Firewall
I have configured Cisco ASA Firewall and I have given ICMP Inspect also But I cant able to ping the PC Kept in the DMZ from the Outside interface
HI,
· Please check the whether the security level for DMZ and outside interface, If DMZ is high security level. Please do the NAT configuration
· If it's having the same security level. Please issue the command "same-security-traffic permit inter-interface "in the global config mode.
Mar 01, 2011 | Cisco ASA 5505 Firewall
I have cisco asa 5510 firewall and i have dialup internet connection i want my asa 5510 between my LAN and my dial up internet
Your best bet is to place the ASA into 'transparent' mode, and letting the traffic pass through it and be inspected on the way through.
To do this you need to first do the following command:
firewall transparent
Once in transparent mode, the firewall will no longer look like a hop in the packets journey, and you can set rules to allow/disallow traffic using access lists on the inside and outside interfaces, plus you can perform packet inspections using policy-map and inspects.
Hope that helps!
Feb 12, 2010 | Cisco ASA 5510 Firewall
Block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
Feb 10, 2010 | Cisco ASA 5510 Firewall
How to block some website on asa 5505?
do the name resolution for the website and write a policy to block the traffic from your trusted network to that website ip address. If required i shall write the policy and give it to you, for this i need the following details.
1. Name of the websites
2. Local network range (LAN ip address with SNM)
But this is very hard for you if there is more number of websites, For this you shall integrate a URL filtering software like WebSense, N2H2 etc with your firewall.
Nov 14, 2009 | Cisco ASA 5505 Firewall
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
How can i block torrent download with asa 5505 firewall????????
It is not possible to block the BitTorrent protocol, as the client applications have the ability to use different port numbers.  I suggest one of the following courses of actions:
1)  Added deny entries to your outbound access-list that block the specific IP addresses of the torrent trackers.  For example: tracker.thepiratebay.org = 77.247.176.145
tv.tracker.thepiratebay.org = 77.247.176.154
tracker.mininova.org = 87.233.147.137
2)  Re-configure your outbound access-lists to allow only services required for business activities.  For example, allow only http, https, and ftp, instant messaging from all your network.  Allow only dns from your DNS servers.  Allow only smtp from your mail server.
Aug 21, 2008 | Cisco ASA 5500 Firewall
Computers & Internet Logo
302 people viewed this question
Ekse
Marvin
Marvin
