I have a RS4 and when I push the spa mode button, the Jandy JVA 2440 (greaseless) actuator spins continuously. The other valves (pool and solar) rotate 180 degrees correctly bu the spa valve continues to rotate. I thout it was just a valve problem but when I flick the toggle switch on the valve to the on 2 position, the valve rotates 180 degrees as it should. Any ideas?
