Question about Hunter Dryers
Fan lights just started blinking, we changed bulbs which were bad but still blinking with new bulbs
  • olofthus
    olofthus Mar 25, 2012
    Worked! Thanks so much for the helping hint! My light works great!
    New Friend:
This problem was posted on several sites, but this was the only one where I found both the cause of the problem and the solution. Mine is a Hunter 5 Minute Fan which came with no remote. And after about a month the two lights would blink together whenever I'd turn them on at the wall. So in case it helps for that type of fan or the same type of wiring arrangment here is what I did: POSITIVE SIDE: P1) Remove the light shade. P2) Remove the 3 screws that hold the cowel and lower the cowel. P3) Disconnect (pull apart) the black and red wire coupling. P4) Cut the coupling off of the black wire that comes up from the lights. P5) Strip off a quarter inch of jacket from that black wire. P6) Remove the wire nut that connects the black wire coming from the governor with the other black wire. P7) Re-use the wire nut to connect the black wire from step P5 with the other black wire from step P6. NEGATIVE SIDE: N1) Disconnect (pull apart) the white to white wire coupling. N2) Cut the coupling off of the white wire that comes up from the lights. N3) Strip off a quarter inch of jacket from that white wire. N4) Remove the wire nut that connects the white wire coming from the governor with three other white wires. N5) Set the governor aside (or just throw it away). N6) Re-use the wire nut to connect the white wire from step N3 with the other white wires from step N4. That's all, you're pretty much done! Turn on the power and test the light. If all is good, re-install the cowel and the light shade.
Posted on Jun 05, 2010
  • 13 more comments
  • Derek Zylka Sep 11, 2010
    Great Tip! My lights were flashing on and off, but the fan worked. I found this fix and removed the limiter and the lights work great. Just out of curiosity I called Hunter to see what their diagnosis was and they confirmed the limiter is bad and is not a replacable part so they are sending an entire new light assembly(that I no longer need). Good ol' U.S. Government at it again!
  • saltador1 Oct 16, 2010
    This worked for me too. Thanks!
  • jwdundee1 Nov 07, 2010
    Rappaho....Huge Huge BEAR HUG...the thought of taking that fan down and fighting with Lowes with a refund THEN having to install a new one was just too much for me. Your post saved me an ulcer. Easy as pie. Again, many thanks.
  • gscottj Nov 14, 2010
    Ditto the comments above. I have a Hunter ceiling fan. I pulled out the governor and re-attached the wires. Whole process took about 10 minutes literally.
  • dbg4 Dec 11, 2010
    I'm trying to follow your directions because my lights are too dim in my fan. By coupling, do you mean that white box like thing that says AA with a band of colors around to LL?
  • Snarf Dec 31, 2011
    Forget Facebook, this is what makes the Internet a community..thanks so much for taking the time to post this. It was clear, concise, and worked to a T!
  • jerry drtz May 17, 2012
    HyperD, hope your fixture doesnt start on fire now that you removed the current limiting device from the fixture.
  • mickmadison
    mickmadison Jul 11, 2012
    Thanks very much! Works perfectly!
    **** - Bethalto, IL.
  • jamwalkerusa
    jamwalkerusa Aug 31, 2012
    Thank You, Thank You, Thank You. Easy does it!
  • milehighbank
    milehighbank Sep 08, 2012
    Thank you!!
  • Wiley Davis
    Wiley Davis Oct 12, 2012
    Same problem only could have been worse! My wife and I started smelling an oder like electrical overheating of bakelite or other plastic like material with our Hunter fan on. On iinspection, I found the "black box", part number 98480-02 had severely overheadted, Insulation on several wires was melted, the black case showed melting points ot it also. I went to the local store where we had purchased the fan, and the clerk there advised someone had recently come in with same problem. It appears to me the reason is poor ventilation to this part that produces a lot of heat. The black case itself has a number of ventilation holes in it, but the light housing that it resides in has no ventilation holes whatsoever. Therefore this is a serious engineering problem from Hunter that could have caused my house to burn up if I hadn't investigated the odor. Apparently from a post below this, the black box or vp;tage gpvermpr was ,amdated bu pir pver;u [rpgectove federa; gpverm,emt om tjeor atte,[ts tp cit bacl pm emergu isage! They should be more worried about their tremendous debt piled up by Obama on foreign nations, and his failed stimulus plans, and his failed green energy boondoggles. It is my opinion this "Black Box" voltage governor should be entirely removed to prevent possible major fire losses.
  • liz_piano2
    liz_piano2 Dec 13, 2012
    Thank you so much for this post. I was able to fix my ceiling fan quickly and without spending a dime.
  • angelagdunca
    angelagdunca Dec 27, 2012
    We had the same issue happen with a Hunter fan in our media room to which we called our home warranty company. The service call cost us $65 bucks. I was able to remove the black box part number 98480-02and wired the fan directly per your instruction. The light works perfectly! Thanks
  • jason_s_ever
    jason_s_ever Jan 21, 2013
    This worked PERFECT! Excellent instructions by rappaho. I almsot bought a brand new fan or maybe just the light kit, but ran across this first! Thank you!
  • Sophia Liam
    Sophia Liam May 08, 2014
    Thanks so much! The instructions are a great help. I wouldn't have even thought to try that. ~Sophia Liam http://www.electrolight.ca/en/
    New Friend:
Looks like this "black box" watt governor (98480) is causing other problems too. I was replacing an older fan which had the lights connected to a fancy electronic dimmer. However, because of this watt-regulator the lights would not turn on at all!
Disconnecting it fixed that problem too!
Posted on Jun 01, 2010
  • 3 more comments
  • ldekle2 Feb 16, 2011
    I assume you connect both white wires together. What about the red and black ones?
  • lorraine_pap Mar 17, 2011
    great tip i had shorted out the black wire when i was installing the light unit this blew the governor
    i just bypassed it and it solve the problem thanks for the tips
  • jernigolf Mar 27, 2011
    Had the same problem with a fan made by Hunter for Lowe's. I just connected the blue wire from the harness to the black wire coming from the light and the white to white. Wires had female and male plugs that plugged right in. Viola worked great.
  • bengietorres Jul 20, 2011
    I follow your instruction and eliminated the governor electric part and connect the black wire to the 4 black wire from the light and the 4 white wire from the light to the neural white wire and fix my light problem of my Hunter Fan.
    Thank you for your comments and help.
  • Pudge Gump
    Pudge Gump Mar 12, 2014
    Yes, my husband is a electrician and said he had never ran into that before! We are all fixed, the niebohood will not think we are having party when we turn our light on ! Thanks again
    New Friend:
Here is the UGLY TRUTH! Part No: 98480-02 a.k.a. "The Black Box", Is a watt governor. I talk to a fan rep. he said that our beloved national government put this into effect in 2008. Bush and Obama did this. Now we are forced to place candelabra lights in our new fans. Fan Co. are now forced to put governors on them too! How ever, Fan Co. can get around this by supplying CFL lights in the box with the new fan. But to keep the cost down they place governors on the fans, YIPPY! I had the same problem flicker lights on my fan, Iopen up the light housing ripped out the black box, holy smokes, it work great.
  • Mitchel Cunningham Nov 06, 2011
    Thank you Pakos Black box in the trash light works great thanks
I had the same problem...I took the little black box out, attached the wires back up and it worked. The black box is under the the switch/socket panel. It's the one with the label on the side with the part number and has slots all over it so you can see the circuits inside. I cut off the plug with the black and white wires coming out and attached those to the same places where the black and red wires were attached (bundles of black wires and white wires which come up from the light sockets). Works like a charm now!
Good Luck
Posted on Apr 16, 2010
    New Friend:
My husband just solved this problem by removing the black circuit box, part# 98480-02, he had to reattach the wires, but now, the light works and actually lights up the room. OUr feeling is that this fan was originally built to use a remote, but due to the hundreds of complaints about faulty remotes, they just sold the fans without the remotes. We think ur fan has been stuck in a "dim" position for 6 months!
Posted on Feb 13, 2010
    New Friend:
Where is the black circut box?
Posted on Apr 06, 2010
    New Friend:
The irony of it is that the government's busy-body attempt to limit wattage backfires: the black box apparently acts like some kind of dimmer, which means even low-wattage compact fluorescent lamps don't work. My fan lights would work fine with four 40W (total 160W) incandescents, but flickered unbearably with four 13W (total 52W power consumption, but equivalent light output of 4x60=240W). The black box on my fan says it limits consumption to 190W, but CFLs draw oddball current waveforms with lots of harmonics, which apparently fools the black box, even with just 52W CFL (actually, a single 13W CFL flickered, with the other four bulbs unscrewed). To avoid flicker, many people likely will use the four 40W instead of four 13W CFL - great energy efficiency! I jumpered around the box and the four 13W CFL (with candelabra base) work fine now.
Posted on Jul 04, 2010
I fixed my flashing light like others. Wired around the government solution to wattage control. Then I threw the government control just as far as I could. I wish I could do that with other government fixes. bowag
Posted on Dec 16, 2011
15 mins and I'm done. My Hunter fan had male and female connectors as if they expected you to remove the limiter and just plug the wires male to female. Lights are bright and no more lag in light coming on from time I flip the switch.
Posted on Nov 09, 2012
Thank you !!!!!! removed the "black box" and the lights are working now!!! This is awesone. We were without the lights for 2 months and I was almost ready to call an electrician.
Posted on Feb 09, 2013
My hunter had a black in and red out, tied those together and two whites tied those together. Blinking problem solved. like the others also a lot more light.
Thanks
Posted on Sep 22, 2012
The issue may be the watt governor. It is a little black box that limits/controls the wattage available to your bulbs. You can try different bulbs or attempt to rewire around the governor. I would ask a fan/lighting store if they have any suggestions on lights to use before trying to do the rewire, because if you don't know what you are doing you may damage fan or yourself. Good luck and be safe! http://fancfans.com/Lighting-Fixtures
Posted on Sep 20, 2014
    New Friend:
I follow your instruction from you and eliminated the black box, governor electric part, and connect the black wire to the 4 black wire from the light and the 4 white wire from the light to the neural white wire and fix my light problem of my Hunter Fan. Thank you for your instruction that help me with my problems.
Posted on Jul 21, 2011
    Sergeant:
    Scholar:
  • Hunter Expert
  • 96 Answers
I would suggest buying a new fan at the price of the replacement part for your existing Hunter Fan. Ceiling Fan Direction have fans at lesser price compare to other online retailers.
http://www.ceilingfandirection.com/ CeilingFanDirection
Posted on Nov 27, 2015
    New Friend:
  • 38 Answers
On the latest model Hunter ceiling fan light kits the wattage limiter is a flat white rectangle (1/8" X 3/16" X 5/8") with two white wire leads.
It is wired between the fan light and the fan socket. It is connected by two wire nuts. After removing the limiter the remaining two wires in the light kit can then be connected together with one of the wire nuts. This part (wattage limiter) is not available from the fan manufacturer.
Posted on Feb 04, 2015
  • VBGSr
    VBGSr Feb 04, 2015
My lights flickered and then died.
Removing the black box part# 98480-02 totally worked!
just reattached all the white wires together and the one back one and you're good to go.
Posted on Jan 17, 2015
I replaced the receiver on my fan and started having problems with flickering lights. First with low energy CFL bulbs which constantly flickered, I switched to fluorescent bulbs these flickered after about 30 mins of use. I just by chance tried a different brand of CFL bulbs (Longstar instead of the GE ones I started with - both 13W) and the no flickering!
Posted on Nov 06, 2014
    Scholar:
  • 92 Answers
Great post! Pulled out the 3 screws holding the fixture assembly up to the fan, the whole thing fell out and there was the odd looking black box in the middle of it all, 2 wires coming in, 2 going out to the lights. Cut the 4 wires, stripped off some jacket, used 2 wire nuts to put together the 2 whites and 2 blacks, screwed it back together, works perfectly now. Thanks!
Posted on Oct 05, 2014
This blog is right on......my hunter fan started blinking. i cut out the regulator box & connected black to the black wires & then tied all white wires together (seven wires) all working fine now & no more 2 second delay. thanks everyone!
Posted on Feb 18, 2012
    New Friend:
Thanks to everyone and their posts! This worked wonderful for us as well. Only difference with our hunter fan is there were two bundles of white wires - one set from the lights, one set from the pull switch and power in coupling. The black wire explanations were spot on, but it seemed like there was only 1 white wire to contend with from the limiter, I had two and two bundles - so I had 7 individual white wires to wire nut with a larger nut. Works wonderful, no flicker!!!
Posted on Aug 03, 2011
My lights started blinking too. I cut the black box out, and tied the wires back together and it worked like new. Thanks for everyone's help!
Posted on Sep 29, 2010
    New Friend:
Thanks guys. Found the "Black Box" as shown. And followed Rappaho's instructions. Worked like a charm.
Great Work Gents.
Posted on Aug 23, 2010
    New Friend:
Thanks for the work around. I have two switches on the wall, one for the fan and another for the light. Now the light switch only works if the fan switch is on. Does anyone know the solution?
Posted on Jul 12, 2010
  • 2 more comments
  • alseiden Apr 25, 2011
    I am so happy I found this. Thank you kpfx for posting the photo too. I disconnected the black box, wire nut direct, works great.
  • oanh_na80
    oanh_na80 Nov 08, 2012
    will this work with a remote control fan too, one without pull cords?
  • Scouser Nov 26, 2012
    Just removed the dimmer control unit from my Casablanca fan unit. It was causing the bulbs to flash. Now the fan works great with CFL too. The original dimmer unit was not designed for CFL usage.
  • Peter Dengel
    Peter Dengel Sep 14, 2014
    Same issue, waited a year, even called the manufacturer they wanted $50.00 for the part. What a SCAM. Saw this note, did it...wow all works fine-
6ya staff
SOURCE:
I have a Casablanca Fan & the lights are blinking?
make sure the wattage in the bulbs are correct
Oct 16, 2014 | Dryers
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
Light blinks when turned on. I have changed light bulb with the proper wattage bulbs.
hi,
check is there is any loose contact in the bulb holder. its the only reason for blinking.
ok
Dec 31, 2010 | Hunter (25417) Ceiling Fan
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Blinks Fast, and Light Stays On.
check the relay and blown out bulbs will cause the lights to blink fast or some to stay on. one bad bulb will cause the problems.
Jul 14, 2009 | 2002 Chevrolet Cavalier Coupe
4805 w/less than 300-400 hours has blinking red light
Yikes. I bet the bearing is bad in the fan and/or the fan is rubbing up against something. It might be an fix.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Dryers Logo
41,666 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
