DVDs aren't universal; what plays in the US won't play everywhere else in the world. There's a chance your DVD is formatted for European viewing or coded for some other global region. North American DVD players are designed for NTSC discs formatted for region 1 or 0.
Here is a solution: http://www.videohelp.com/dvdhacks/samsung-bd-c6900/10895
Please note, however, that even
after region code hack, it may remain NTSC only, so if you are planning to
play European DVDs recorded with PAL system, it may not work.
Where did u bought this DVD player?US,Canada,and Mexico?The DVD disc. used NTSC region format.Asia,Europe,Africa,and the Middle East.The DVD disc. used PAL region format.They can't be mix or it will not play as u find out.If u move in and out to another region of the world.U must have a regions free DVD player to play either NTSC or PAL regions.
Short answer:I need the make and model #
Long answer:Some manufacturers, Philips for example, is fairly liberal of locking their DVD players to one region. It is very easy to unlock philips player, try googling "(brand) region free code" and there will more than likely be articles and sometimes instructions on how to unlock a particular model. Every DVD player is different so there is no one way of doing it. Sony, panasonic and other brands are stringent on their multi region capabilities. I'm not saying there are not ways of doing it, but sometimes it actually requires opening the dvd player and changing something inside, other times it can only be done if the factory before they ship out. Blu-ray has a region restriction also, but I will let someone else more familiar with that format explain that.
VHS players in the states is in NTSC format and in some countries they are in PAL format. The only way to get a PAL to play on an NTSC is if the VHS is capable of playing that format. You cannot do anything to make it play PAL. It's kind of like putting a DVD in a CD player and expecting it to work. It just doesn't work that way.
you need to check that it supports pal output, if its a european unit
(check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
2. Enter RC6 command via Pronto
[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
2.1. The remote should be set up to control the DVD (setup code 0539).
2.2. Press the DVD button.
2.3. Press the Magic button.
2.4. Press 085.]
2.5. The display should read '----'.
2.6. Enter the following with the normal Philips remote:
[On newer models, there appears to be 11 spaces in which to enter a code].
222 222 005 255
The player should now be able to output pal progressive scan + be region-free.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
