How can i replace the touchscreen of a LG KF600
If you are technically minded, yes, you will be able to do this yourself. Otherwise you need a technical person to do it for you.
I assume you are technical. This is what you should do:-
1. You should have the replacement touch screen handy (You should have bought a new touch screen).
2. Remove battery, memory card, sim card etc.
3. Unscrew the screws holding the casing/(housing of the phone) to the panel.
4. Then with object like a knife, position the edge gently between where the lower and upper parts of the casing contact/(close up) and pry open.
5. You will see where you can disconnect the touch screen from the panel. Gently detach from the panel. Connect the new one and reassemble.
